003234: The combination of dataset registration types is not supported by the replica.
The input replica datasets are in a combination registration state that is not supported for creating replicas. For example, one dataset is registered as versioned and the other is not registered as versioned.
Solution
Check the registration requirements of the replica type.
Two-way replicas require data to be registered as versioned.
One-way replicas require data to be registered as versioned for the source (the target in one-way replications can be nonversioned if using a simple model).
Checkout replicas allow versioned or nonversioned data but cannot contain a combination of both registration types. If you're working with nonversioned data, a combination of archive-enabled data and data without archiving enabled is not supported.
Branch versioning is not supported for any replica type.
