003309: Unable to Create Replica with Register Existing Data Only option. The following datasets are missing in the target geodatabase: <value>
The datasets in the target geodatabase must match the datasets from the source geodatabase and be owned by the connected user from the database connection file used for the Geodatabase to replicate data to parameter.
Solution
Connect to the target geodatabase and ensure that the datasets with the same names are present. If related data is missing from the target geodatabase and is not needed for the replica, use the Do not add option for the Expand Feature Classes and Tables parameter.
