003526: Parameter <value> is not present on the <value> tool and is a Model variable, the tool cannot be converted
The analyzer identified a compatibility issue with a tool parameter.
A parameter is not present at the target version. In the input model, the missing parameter is exposed as a variable and the variable is exposed as a parameter of the model.
Solution
This compatibility issue cannot be addressed automatically. Try the following:
  • Use a later target version in which the compatibility issue is not present.
  • Modify the model or script tool to use an alternative, if one exists, to the problematic tool or parameter.
