003528: Parameter <value> is not present on the <value> tool and is not at end of defined parameters, the tool cannot be converted
The analyzer identified a compatibility issue with a tool parameter.
A parameter was identified as missing from the target version. This parameter was not added to the end of the defined parameters and may cause compatibility issues when saved to the target version.
Solution
This compatibility issue cannot be addressed automatically. Try the following:
Use a later target version in which the compatibility issue is not present.
Modify the model or script tool to use an alternative, if one exists, to the problematic tool or parameter.
