003530: Parameter <value> on the <value> tool has a change to it's place in the parameter set, the tool cannot be converted
The analyzer identified a compatibility issue with a tool parameter.
Tools have a set of parameters that are in an explicit order. The order of the identified parameter was changed, which will cause problems when the toolbox is saved and used with the target version.
Solution
This compatibility issue cannot be addressed automatically. Try the following:
  • Use a later target version in which the compatibility issue is not present.
  • Modify the model or script tool to use an alternative, if one exists, to the problematic tool or parameter.
