003533: Parameter <value> on the <value> tool has a change to dataType (from <value> to <value>)
The analyzer identified a compatibility issue with a tool parameter.
The parameter's dataType property has changed.
Solution
This may not indicate a problem. If the type is valid for the dataType property at the target version, the model or script may generate the expected result.
Use the target version of the software to review the processes in model and script tools that were identified with compatibility issues. Review the version-appropriate tool documentation, run the model or script tool, and review the output to confirm it is acceptable.
