003535: Parameter <value> within Tool <value> converted its value from MultiValue using first out of <value>
In the current version, the parameter supports multiple values; however, at the target version, the parameter only supports a single value.
The analyzer applied the following fix to the compatibility issue: multiple values were detected in the original model, but only the first value was saved to the output toolbox.
Solution
Use the target version of the software to review the processes in model and script tools that were identified with compatibility issues. Review the version-appropriate tool documentation, run the model or script tool, and review the output to confirm it is acceptable.
