003547: Parameter <value> on the <value> tool has a change to it's position in the parameter set, the tool may not run correctly
The analyzer identified a compatibility issue with a tool parameter.
Tools have a set of parameters that are in an explicit order.
The parameter's position is not consistent at the current version and the selected target version.
Solution
Use the target version of the software to review the processes in model and script tools that were identified with compatibility issues. Review the version-appropriate tool documentation, run the model or script tool, and review the output to confirm it is acceptable.
