003550: Parameter <value> on the <value> tool has a change to MultiValue property, the tool may not run correctly
The analyzer identified a compatibility issue with a tool parameter.
The analyzer identified a compatibility issue. Tool parameters have a multiValue property that can be either true or false. This property controls whether the parameter accepts multiple values or only a single value.
The parameter's multiValue property is not consistent at the current version and the selected target version.
Solution
Use the target version of the software to review the processes in model and script tools that were identified with compatibility issues. Review the version-appropriate tool documentation, run the model or script tool, and review the output to confirm it is acceptable.
