003554: Error while loading netcdf metadata: <value>
The input netCDF files do not have the expected CF convention metadata, or a problem with the input netCDF files was detected.
Solution
Missing or incorrect CF metadata can be supplemented using an .ncml file in the Input Climate and Forecast Metadata parameter.
If a lower-level error was encountered, use ncdump to determine the problem with the netCDF metadata and correct the data before using the tool.
