003565: No vertical datum information present in inputs. WGS 1984 Ellipsoid Height (wkid 115700) will be assumed. Axis direction and vertical units will be preserved but data cannot be transformed into another vertical datum.
The input netCDF files do not have proper vertical datum information defined.
Solution
Use an .ncml file in the Input Climate and Forecast Metadata parameter to supply precise vertical coordinate system metadata for the input netCDF files.
