003614: Split Address Into Components failed.
The address splitting process failed. One of the following issues may be the cause:
  • The output workspace is on a drive that is not accessible or is invalid.
  • The Exceptions File parameter value is in the wrong format.
  • The Input Address Data parameter value is in the wrong format.
Solution
Ensure that the following are true:
  • The Output Address Data parameter value is a valid location.
  • The Exceptions File parameter value is formatted correctly.
  • The Input Address Data parameter value is in the correct format.
