003642: A networking error occurred.
The heap size setting controls the maximum file size that can be provided from the client. Network errors such as this may occur if the payload of a trace operation is larger than what can be accommodated by the default heap size of 64 MB.
Solution
To determine the proper heap size setting necessary for a utility network service to estimate the total number of junction and edge elements traversed by a trace, consider the following:
The default payload size of a trace without results is approximately 750 bytes.
Each additional junction element introduces approximately150 bytes.
Each additional edge element introduces approximately175 bytes.
The following baselines can be used to estimate the proper heap size setting for a utility network service:
64 MB (default) should be sufficient to return approximately 200,000 edge elements and 200,000 junction elements.
128 MB should be sufficient to return approximately 400,000 edge elements and 400,000 junction elements.
256 MB should be sufficient to return approximately 800,000 edge elements and 800,000 junction elements.
The existence of midspan connectivity along a line creates multiple edge elements for a single feature. For example, an edge feature with 9 midspan junctions consists of 10 edge elements, requiring 2500 bytes: 750 + 10 * 175 = 2500.
Similarly, terminal devices return a junction element for each terminal defined.
