003679: <value> was set to <As defined in data>, but fields in data not mapped.
The Country or Region or Language Code parameter value was set to <As defined in data>, but the Country Code and Language Code address component fields in the Street Field Mapping parameter were not mapped. The input point and street features should have fields that contain the three-character code for country and language that are used in the point and street field mapping parameters for optimal street assignment results for the country or region; otherwise, the country and language should be specified using the Country or Region or Language Code parameters.
Solution
Ensure that a country or region is selected from the list of values for the Country or Region parameter or a language is selected for the Language Code parameter value and that the Country Code and Language Code address component fields are not used as values in the Street Field Mapping parameter.
