003710: Update Subnetwork must be run before exporting a dirty subnetwork with acknowledgement with a disabled subnetwork controller.
When you remove a subnetwork controller by marking it for deletion using the Modify Subnetwork Controller pane, an update subnetwork operation must be run on the subnetwork before it can be exported with the acknowledgement set to true.
Solution
Update the subnetwork and rerun the export operation.
