003777: A file named <value> already exists in this folder and the geoprocessing option to overwrite existing datasets is not enabled. Change the folder or rename the file and try again.
There is an existing file with the same name in the portal folder. The existing file cannot be overwritten because the option to allow geoprocessing tools to overwrite existing datasets is not enabled.
Solution
Do one of the following:
To overwrite the existing file in the portal, enable the Allow geoprocessing tools to overwrite existing datasets geoprocessing option. The input file must have the same name, title, and selected portal folder as the existing file.
To upload the file as a separate item, change the folder or rename the file.
For more information, see Geoprocessing options and Upload File To Portal.
