003778: A file named <value> already exists in this folder with a different title. To overwrite, use the title of the existing item. Otherwise, change the folder or rename the file and try again.
The file already exists in the portal folder but with a different title. To overwrite an existing file, the input file must have the same name, title, and portal folder as the existing file. Alternatively, you can upload the file as a separate item.
Solution
Do one of the following:
  • To overwrite the file, type the title of the existing file in the Title parameter.
  • To upload the file as a separate item, change the folder or rename the file.
For more information, see Upload File To Portal.
