003805: An output was not created due to no matches being found in the Source to Target Mapping parameter.
When using workspaces as input, layers and tables are matched by name similarity. If no matches are found, no workbooks will be created.
Solution
Use the Mapping Table to define the layers or tables to be matched. You can also map layers and tables directly using the Source to Target Mapping parameter.
