003940: ArcGIS Server connection not found.
When running the Synchronize Changes tool, the Geodatabase 2 parameter value may be a geodata service that contains the replica that is related to the replica in the Geodatabase 1 parameter value. The ArcGIS Server connection file that is used to connect to the site where the specified geodata services are running cannot be found.
Solution
Confirm that the path to the connection file is valid. Create a new connection file if necessary.
Learn more about replica synchronization
