003963: Path not found.
No valid paths were identified between the starting and stopping points provided for the path trace. This can be caused by various issues such as the following:
No connectivity exists between the starting and stopping points.
The only valid paths exceed the value provided for the Max Hops parameter.
Solution
Ensure that proper connectivity exists between the starting and stopping points by running the Update Is Connected tool to identify isolated areas and address any connectivity issues. Alternatively, increase the Max Hops parameter value on the Trace tool to enable additional paths to be discovered.
