004031: '<value>' has existing match narrative fields.
The input feature class to the Split Match Narrative Into Fields tool already contains match narrative fields.
Solution
Do one of the following:
Select a geocoded feature class that does not have match narrative fields attached to it, then run the Split Match Narrative Into Fields tool.
Remove the joined match narrative table from the feature class specified as the Input Geocoded Features parameter value using the Remove Join tool. The joined table has the same name as the input feature class with
_MatchNarras a suffix.
