004096: There are only <value> data samples to cluster, which is not enough.
The number of data samples is too small for clustering.
Solution
Lower the Maximum Number of Classes, Maximum Number of Cluster Merges per Iteration, or Minimum Number Of Samples Per Cluster parameter values. However, if these values are too low, the results may not be meaningful.
