004098: A field is assigned to a domain that is not defined in the XML Workspace Document.
When using an XML workspace document to import schema or data into a geodatabase, this error is returned when there is a field defined in the XML workspace document that has a domain assigned to it but the domain has not been included in the XML workspace document.
Solution
To successfully import the schema or data, the domain must be defined in the XML workspace document, or the domain can be unassigned from the field. You can use the Domain Usage tool or open the Fields view to see domains that are assigned to fields in the tables and fix the issue. Then run the Export XML Workspace Document tool to generate a new XML file.
