004127: Include offset metadata fields requires the input feature class to be POINT feature type.
The Include offset metadata fields parameter is only supported when the input is a point feature class. If the input is not a point feature class, the tool will run successfully, but the offset metadata fields will not be added.
Solution
Check the Include offset metadata fields parameter or provide a point feature class as input.
