004164: The <value> and <value> have the same path. The resulting Arcade expression may produce a cyclic evaluation error when triggered.
The Input Table parameter value and the Target Layer value are the same.
Solution
Do one of the following
  • A Search Type value of Match Fields, Relationship Class, or Spatial Only is not allowed when the Input Table and the Target Layer are the same class or table. Specify a different Search Type value if available.
  • If the Search Type value is one of the utility network association types (for example, Connected (UN Association)) and the Input Table and the Target Layer are the same class or table will generate a warning. To prevent cyclic errors after importing the new generated rule, choose one or more applicable subtypes in the Attributes Rules view.
