004167: <value> parameter is not supported for a service definition staged to overwrite an existing service.
The item ID value cannot be used when uploading a service definition that is set to overwrite an existing service.
Solution
Remove the item ID value; the service will use the item ID of the existing service it is overwriting. If no existing service is found on the server, an item ID will be automatically assigned.
Alternatively, create a service definition file that is not set to overwrite an existing service.
