004172: <value> parameter is not supported to ArcGIS Enterprise 10.8 and earlier.
You are uploading a service definition to ArcGIS Enterprise 10.8 and earlier. You can only specify item IDs when sharing the following types of layers to the corresponding ArcGIS Enterprise versions:
  • Web feature layer that copies all data—ArcGIS Enterprise 10.8.1 or later
  • Web tile layer—ArcGIS Enterprise 10.8.1 or later
  • Map image layer—ArcGIS Enterprise 11.2 or later
  • Web feature layer that references registered data—ArcGIS Enterprise 11.2 or later
  • OGC feature layer—ArcGIS Enterprise 11.2 or later
  • WMS service layer—ArcGIS Enterprise 11.2 or later
  • WFS service layer—ArcGIS Enterprise 11.2 or later
Solution
Upgrade your version of ArcGIS Enterprise. Alternatively, remove the item ID parameter; an ID will be automatically assigned.
