004245: Field <value> has no data. The locator will not contain this output field.
A field specified in the Polygon Output Field(s) parameter from the Polygon Features parameter value does not contain data and will not be added to the locator. The identified field will not be included as an output field in the geocode results or in the Batch Output Fields list on the Output fields page in the Locator Properties dialog box.
Solution
Ensure that the intended field contains data before specifying it in the Add Polygon Fields to Locator tool.
