004264: Invalid character in parameter - <value>.
The knowledge graph service, entity type, relationship type, property name, or data store name contains an invalid character. The following are naming restrictions for the different components of a knowledge graph.
Knowledge graph service—Unicode characters can be used with some restrictions when creating a knowledge graph as follows:
The service name cannot start with a number, a period (.), an underscore (_), or the text
esri__. Also, leading and trailing spaces are not permitted. These characters can be used between other characters in the name.Some characters are not permitted anywhere in the service name, including the forward slash (/) and colon (:), as well as control characters such as \n and \r that correspond with ASCII codes less than 32.
The name must have a maximum of 111 bytes.
NoSQL database—Any Neo4j or ArangoDB database that is registered as a NoSQL data store must have a name or alias that meets the same criteria as the knowledge graph service.
Entity types, relationship types, and properties of entities and relationships—When defining a property for an entity type or a relationship type, these names are subject to similar restrictions as knowledge graph services as follows:
The property name cannot start with a number or the text
esri__.Some characters are not permitted anywhere in the property name, including spaces and ASCII symbols such as the forward slash (/) and colon (:), as well as control characters such as \n and \r that correspond with ASCII codes less than 32.
The name must have a maximum of 64 Unicode characters.
The name must not be a reserved keyword in any associated system such as
objectid,globalid,NONE,RETURN, andCONTAINS.
Solution
Provide a new name that satisfies all naming restrictions.
