004271: Map contains knowledge graph layers from different knowledge graphs.
The input feature layer is from a map with knowledge graph layers from different knowledge graph services. The input feature layer must come from a map where all knowledge graph layers use the same knowledge graph service.
Solution
Create a new map that contains the knowledge graph layer you intend to use as the input feature layer. Alternatively, remove knowledge graph layers that will not be loaded from the map.
