004534: Failed to add frame at timestamp <value>.
A frame at the given timestamp could not be added to the oriented imagery dataset because its metadata was unreadable, incomplete, or invalid.
Solution
Verify that the video contains valid frame metadata and ensure the embedded metadata includes the required KLV fields.
For AerialFrame confirm that Precision Timestamp, Sensor Latitude, Sensor Longitude, Sensor Ellipsoid Height or Sensor True Altitude, Platform Heading Angle, Platform Pitch Angle, Platform Roll Angle, Sensor Relative Roll Angle, Sensor Relative Elevation Angle, Sensor Relative Azimuth Angle, Sensor Horizontal Field of View, and Sensor Vertical Field of View metadata fields are present and valid.
For TerrestrialFrame and Terrestrial360 confirm that Sensor Latitude, Sensor Longitude, Sensor Ellipsoid Height, and Precision Timestamp metadata fields are present and valid.
