010029: Unable to create the Grid <value>.
There was a problem trying to create the specified grid. This might occur if a file with the same name already exists at that location, or you might not have the correct permissions.
Solution
If a grid with the same name already exists, use a different name or delete the original if it is not needed.
Make sure you have write permission to the output location.
