010071: Grid write error.
There was an error encountered when trying to write the grid. The most likely cause is not having write permission to the output location. It is also possible that there is insufficient space available.
Solution
Some suggestions to avoid this problem are as follows:
Check to ensure that you have write permission to the output location.
Check that you have write permission to the location.
Check that the output workspace is valid.
