010084: Invalid command or expression.
The specified command or expression the command is used in is invalid. This may occur if an improper command name was used or the syntax of the expression was incorrect.
Solution
Ensure that the syntax of the command is correct. You can find the correct command names and syntax in the tool documentation. Also, review the documentation for Map Algebra expressions.
