010090: An invalid or null filename was obtained from the path specification.
A valid file name could not be found after parsing the specified input path.
Solution
Check the input path to remove any invalid characters or symbols, such as *, ?, ", <, >, and |.
For accessing data on a network folder, the UNC path should have the following syntax:
\\<computer name>\<shared directory>\...
For example:
\\majestic12\data\groom_lk\...
In Python scripting, note that the backward slash (\) is reserved for other purposes, and \\ or / should be used as the separator in a path.
For example:
\\majestic12\\data\\groom_lk\\...
