010113: The signature file <value> has no covariance matrices.
The signature file that has been specified does not have a covariance matrix. In a supervised classification, statistics are calculated for each class as identified by training samples. In an unsupervised classification, the classes are defined by statistically grouping cells into a specified number of clusters. The statistics for the classes are stored in a signature file. The signature file is then used as input to other multivariate statistics tools, generally to perform a classification. The most common reason for a covariance matrix not to be created is that, when creating the signature file, the specified training samples and input bands were insufficient.
Solution
Open the specified signature file to see if any covariance matrices were created. If not, try re-creating the signature file.
Check to make sure the training samples have enough cells in each class, that there is a good representation of the feature in the class, and the classes are distinct from one another.
Also make sure the input bands are not duplicated, the bands are parametric (represent continuous values), and there are multiple bands entered into the signature file.
