010151: No features found in <value>. Possible empty feature class.
There were no features found in the specified input. It is possibly an empty feature class. This may also occur if there is no overlap in the extent of the inputs with that defined in the environment.
Solution
Investigate the input dataset to determine whether it actually contains some features. Check that the dataset and any environment settings will have some common extent.
