010163: Unable to open stack <value>.
The specified Grid stack could not be successfully accessed, perhaps because the path is incorrect. It is also possible that the Grid stack is malformed. A more detailed description of the format of a Grid stack is available in the documentation.
Solution
Check that you have correctly identified the Grid stack. Check that the Grid stack is valid. If it is not, you may need to re-create it.
