010200: PATHDISTANCE: No data in the vertical factor parameter file.
The vertical factor parameter file that you entered either is empty data or is in a format that is not accepted by Path Distance. The vertical-factor graph defines the relationship between the vertical cost factor (VF) and the vertical relative moving angle (VRMA). The vertical parameter file is an ASCII file used to produce the graph. The file should have two columns. The first column identifies the VRMA in degrees, and the second, the VF.
Solution
Check that the input vertical factor parameter file has valid content and is in the correct format required for Path Distance.
