010211: Could not open the specified point file <value>.
The input point file could not be read. This might happen if you do not have the appropriate permissions to read the file. The point file may also be incorrectly formatted or an invalid ASCII text file.
Solution
  • Check that you have permission to read the file.
  • Check that the file is properly formed. You can use any text editor. The documentation for the tool you are using will provide details on the correct format.
