010214: Unable to read <value> of <value>.
There was a problem reading the specified component (value1) of the input dataset (value2). This might occur if the component is missing or possibly has been corrupted.
Additionally, you may see this error for some Spatial Analyst operations that require the input rasters have certain statistics properties. The conditions that may make the specified datasets invalid include:
  • The statistics have not been calculated.
  • The statistics contains a skip factor greater than 1.
  • The statistics contains an ignore value.
Solution
Check that the dataset is valid. If it is not, you may need to re-create it or retrieve a backup copy if you have one.
If the input raster dataset's statistics are invalid for any of the reasons listed, use the Calculate Statistics tool to calculate the appropriate statistics for the dataset.
