010228: Could not find remap record.
Either the data could not be classified by the defined remap object or the remap record of the specified index cannot be found.
Solution
  • If you are performing a remap on number fields, use the NumberRemap object. Also, use NumberRemap to remap single values or ranges of values.
  • If the remap is to be performed on a string field, use the StringRemap object and specify the field in the raster descriptor.
