010229: Failed to build remap for selected values.
There was a problem with the INFO table that records the zones to select for expanding or shrinking. The table should only list single values, not a range. The values should also be sorted from lowest to highest. The documentation provides further information on the selection table.
Solution
  • Check that the contents of the table comply with the requirements.
  • Check that the INFO table exists at the specified location.
