010232: Unable to rename a dataset to <value>.
The dataset could not be renamed. This could be due to any of the following reasons:
The new name is invalid.
There may already be a dataset at the location with the same name.
The dataset is locked as a result of being accessed by another ArcMap or ArcCatalog session.
You do not have permission to rename the dataset.
Solution
To avoid this problem, ensure the following:
The name change for the dataset is valid.
The name is unique to that folder.
The dataset is not being accessed by another ArcGIS session.
You have the correct permissions.
