010243: Unable to set mask.
The process failed to either set or honor the mask during execution.
Solution
Check that the dataset used to set the mask is valid. Also check the output extent. It is also possible that mask is not honored by the particular tool being used. Check the usage tips in the tool documentation to determine if this is the case. Note that either a feature or a raster dataset could be specified as the mask.
