010244: Could not set the analysis window.
The output extent or cell size could not be properly set. Reasons that may cause this situation include these:
The output extent has not been explicitly specified.
A valid cell size could not be determined.
The inputs do not intersect if the Extent environment is set to Union of Inputs (Minimum of).
Solution
Specify a valid extent in the environment. You can also specify extent as an input to a tool if a parameter is available.
