010287: Unable to resample grid <value>.
The input grid could not be resampled. This might occur if there is a problem with or locating the specified input grid or if the analysis window or cell size is invalid. If the cell size to resample to is set to be close to or larger than the size of the analysis window, it could cause resampling to fail.
Solution
Make sure both the input grid and workspace are valid.
Check that the cell size setting is appropriate.
Check that the analysis window/extent is valid.
