010290: Unable to set the output window.
The output analysis window was not set. This may occur if the coordinates were not correctly specified or the specified dataset to obtain the window coordinates from does not exist or is invalid.
Solution
  • If the extent is defined by coordinates, make sure they are the correct numeric values.
  • If the extent is to come from a dataset, make sure it exists as specified and is valid.
