010296: Error in writing grid <value>.
There was an error in writing to the specified output grid raster. This might occur if there already exists a grid with the same name at the output location or you do not have the correct permissions.
Solution
Check that a grid with the intended name does not already exist. Either use a different name or delete the other grid if it is not needed.
Check that you have the correct permission to write to that location.
