010333: Invalid WEIGHT neighborhood mask.
There is a problem with the kernel file being used to define the weight neighborhood. The kernel file is an ASCII text file and must be in a specific format. The documentation for the tool you are using will give more information on the weight neighborhood kernel file.
Solution
Check the documentation and make sure the weight kernel file is valid.
